99% of the time I mount the motor to the firewall.. I very rarely use the X mount. Use the X mount to check which holes to use. Take your drill and enlarge a hole if need be. I'm guessing you are using the pre-drilled FT firewalls. Not all of them fit perfectly and may require some adjustment. Also, you can get by using only 2 of the screws.
