On my cubs, the power pod is removable for battery changes as the nose isn't really long enough to do it any other way but that cessna has plenty of room to have a lift of panel.That's REALLY nice Mate! ๐๐ Just about the right size.
I don't trust Chinese sellers on FleaBay (like that one too!)...
But I will buy from Domestic Distributors - ONLY if they have a 98% or higher Feedback rating, and OVER 10,000 Feedbacks. I've actually had a 100% success rate, so far in 12 years!
I may be taking your lead on the Power Pods... I have no intention of Swapping any out, plus the Firewall can be made MUCH stronger! ๐
And, if financially able, I'd be like you and many others...
Up to my elbows in half finished Aircraft!!! ๐
Unfortunately, I built and painted it before I thought about it and so it was a surgery job and I had to modify the nose rather than building it that way from the start, I've attached pics of my cessna 180.
I've also got a ft racer which has the whole nose as a top hatch, that one I already knew I wanted to do that way and modified the construction of it rather than hacking it apart after building it, it does not even have a power pod, I built the Firewall into a box section which is only about one inch long.
Pics of that plane are also attached.
For my firewalls, I use 1 mm aluminium sheet, it's much stronger, does not weigh much different to ply and also acts as a heat sink for the motor.
To bond it to the foamboard, I score the aluminium that will make contact in a diamond pattern with a blade and also come in at an angle so that the blade cuts a lip in the surface of the metal instead of just scoring it for something better to bond too and I use epoxy resin to bond it.
You don't need much, epoxy bonds it very well to the foam.
My aluminium firewall is again, attached
I know all about being broke, I went through a period around 3 1/2 years ago where I didn't know if I would have enough money to even eat each day, my life was a mess after I split with my wife and being permanently signed off sick I was not getting much money.
Things are different now, I'm not rolling in it but I'm comfortable since I was granted disability (mental health not physical) money on top of the basic benefits.
I couldn't have this hobby if it wasn't for that help!
Hot glue is plenty strong enough to hold it, it won't break free and just a slit is plenty to cool the esc anyway, you don't need to do proper ducting.Well Steve, I've implemented your Nose Skid, adding an odd NACA Duct, to cool the ESC right under the Power Pod!! ๐๐
I had to come up with some creative bracing, because I didn't just want Hot Glue holding it down.
I did score up the underside of the Plastic Plate, and the Fuse.
Now to wait for everything to cure, sand, paint....
WAIT TO FLY!!!
I will never trust just Hot Glue at over 115F!!! That's the consensus of most of us in Arizona. Besides, Gorilla Glue weighs LESS.
I pulled some unnecessary bracing out of it, and will weigh again tonight...
I love the bright Wing idea! I did mine in an almost fluorescent Blue, with Dark Tips, to see her in bright and cloudy skies... hopefully!
Like the Camera idea. Small enough too.
It looks great! Just send it!!!I'm going with the suggestion of @Hai-Lee and adding incidence to the Wing. Starting small, about 9 degrees.
Now, I'll probably get to hear more about how it's not going to Fly! ๐
Thursday's STILL looking good for a Maiden. Naysayers are actually making me nervous....
But it's happening no matter WHAT! ๐๐
THAT'S the idea!! I'm hoping and praying that the Weather Guy didn't do too many drugs this week, and actually got it RIGHT.It looks great! Just send it!!!
Just a note! The increase in incidence angle should be minor around 1 to 2 degrees. The wing drag and lift increase greatly beyond this and with too much lift you will need MASSIVE downthrust angles on the motor. In addition at around 15 degrees the lift falls off rapidly and at the same time the drag increases again massively.I'm going with the suggestion of @Hai-Lee and adding incidence to the Wing. Starting small, about 9 degrees.
Thank you! I take all constructive criticism! ๐Just a note! The increase in incidence angle should be minor around 1 to 2 degrees. The wing drag and lift increase greatly beyond this and with too much lift you will need MASSIVE downthrust angles on the motor. In addition at around 15 degrees the lift falls off rapidly and at the same time the drag increases again massively.
If you try it at 9 degrees you may find that it wants to push its nose up under power and will want to glide nose down for level flight!. Take a few shims with you for the wing TE in case you find it impossible to control with the motor at any more than 50% throttle.
Have fun!
My version weighs a little less than your version and I added huge tundra like tyres, (rather heavy). I normally just wedge up the LE of the wing with paddle pop stick.Thank you! I take all constructive criticism! ๐
The Wedge up front is uncovered Foam Board. I can easily sand more off...
Bring it down to about 3 degrees?
Even after shaving the weight down to 740g - with nothing else I can really lose...
NOT LOSING THE LANDING GEAR! (Not addressed towards you๐), but still she's a bit chunky.
I've got ample Thrust with the 10x4.7, but I'm now second guessing EVERYTHING.
I can't WAIT till she gets off the ground!!
If it goes up, spins and lawn darts into a rock, you all will see it...
And I've got 3 more Planes on the drawing board.
A Scout arriving any day now, my Son is trying to resurrect the Storch, and another friend is cutting me an Edge 540 - WITHOUT the Control Surfaces cut, so I can experiment with making a more docile flyer...
Then the same guy is cutting me a P-40!
He'd do a P-47, but we can't find the plans......
It'll be fun no matter WHAT!
That weight is 740g WITH an 1800 MAh 3S Batry!!
We have different parameters and needs...
I NEED Landing Gear! There is no grass, weeds or brush around me. I live in a Desert! I'm Landing on HARD, rocky, packed dirt.
I made the Gear removable, like the plans. The only other choice I have for a landing surface is - Sand. There I will Belly Land, and only when I've got someone with me who can retrieve it for me.
I've got the weight down enough, I've got plenty of Thrust. She's FLYING!!! It's just a matter of when - at some point THIS week. ๐ป
..... And the Wing Alignment Strips - didn't even register on the Scale!
