Simple Gliders - getting back into foam
bracesport
I recently decided to offer my skills to the local college primarily in CAD and design - but along the way, they told me about their Aeronautics club which I also offered to get involved with - they are lucky enough to have a reasonable laser cutter so I suggested we could make some DTFB gliders!
Last week I sent them the files to cut the Simple Soarer and before I even got to the first meeting they had cut and built a couple already - the build quality was not bad for a first go, but they had used 3mm FB and the templates were for 6mm FB which meant the bends were a bit rough - initially, they had forgotten the polyhedral in the wings, but we put that right - we also went through some of the techniques for bending and glueing and I updated their templates to suit 3mm FB so we will see what they achieve next week!
These kids are a mix of ages but they are keen as mustard - once we get the build quality right and they get a feel for a nice glide from a hand throw we will look at adding some RC gear!
SlingShot
Maneuvering With Purpose
View attachment 178115 View attachment 178116
Digging those jackets. Those boys look like they are ready for the barbershop quartet. ;)
bracesport
Well, the Simple Soarer has proved challenging for the boys - the size is a bit big for the first-timers and given they only have 3mm FB sheets, the scoring and folding is a bit more fiddly - so I thought we could try the EZ glider which is a smaller glider and made from one sheet.
I converted the files for the laser cutter and for some reason the first sheet cut without the score lines, so I offered to take it home and build it up with my son (and convert it to a 2ch of course)! Stage one before dinner - gouge out the channels, glue up the fuselage, and start on the tail feathers. :)
bracesport
We had a bit more time this afternoon so we cracked on and made the wing - this 3mm FB is card covered rather than paper covered, so it is nice and stiff, but a tad heavier - I use a small screwdriver to open up the bend points which allows a reasonable amount of glue to get in while providing an easy bend - as we are using 3mm board I added a strip under the spar bend to build up the height of the foil.
For the students, I will take this one along as an example build - if I don't get the servos in we can do that part together, although we only have 3/4 of an hour each week at the aeronautics club, it would be nice for them to see a completed product.
bracesport
I added a couple of 9g servos (ran out of 5gs) and threw in an FSiA6b RX and 2Cell Lipo - it is a small glider and with controls at the tail (aft weight) the nose balancing requirement creeps up - regardless of all the onboard gear that is not optimised for the weight we still needed some lead - we will see if it flies! :)
The Hangar
Fly harder!
Timmy
View attachment 182487 View attachment 182488 View attachment 182490
I like how the antennas stick out! Give it googly eyes and paint it like an insect. The antennas could be the insect's antennas. :p
bracesport
Well it flies! The boys had their first go at using an RC glider and they loved it - the conditions at the park were a tad blustery, but they managed to float in the breeze remarkably well - it was a bit tail heavy so I will tweak it a bit to penetrate better.
I think I will change the design with a slightly wider wing in the same fuse as the 3mm FB is heavier so needs a bit more lifting force.
The Hangar
Fly harder!
View attachment 182506 View attachment 182507 View attachment 182508
Awesome!! Looks like you were having a lot of fun! (y):D
