Focusing on my nutball build at the moment, so not a whole lot more to come on this until I've built and flown successfully. I'll update if some new Idea just comes. At the moment, the newest information I'm looking into tends to suggest that for sharply angled delta wings, dihedral(though at first thought a great idea!) has a negative effect on lift. surprisingly, a slight anhedral has the opposite effect, and in theory would not only lend a bit of stability, but increase lift a bit as well. I'll have to do research into how the anhedral would interact with the vortex effect created by the wing profile, but so far I see no evidence of that throwing it off or negating it.
In the end, if I want to play it completely safe, I may use a flat wing just like the hp-115, but experimenting with slight anhedral is tempting. The biggest hurdle in building this is deciding whether to go for the ducted fan or try it on a normal pusher. From what I'm looking at, ducted fan will give me a nicer end product, with a bit more power and stability, and a cleaner profile that I can affix low profile landing gear to easily. The pusher is looking like a bit of a clumsy hand launch design, but that may work fine, especially if the anhedral option bears any fruit. The attraction is that ducted fan setups seem a lot more expensive and I have no experience with them. If I could test the concept successfully with an F pack, I'd have the confidence to maybe invest in a fancy ducted fan build later.
If I could get the build to run as cheap as possible on a simple FT power pack, I think it would be a lot more popular for others to build and experiment with, but if there's any ducted fan aficionados who would know how to do the EDF in an economic manner, by all means chime in, I'd like to know!
