Glad to hear that you are not giving up. I would advise to think carefully about scaling this down. Although you will use less foamboard and possibly make it easier to balance on the CG, you will also increase the wing loading quite a bit which will make it harder to fly. Given that you are in the process of learning to design, build, and fly, smaller makes the fly part harder.
Second thing to think about is your wiring. You will want to be able to put the battery as close as possible to the nose to balance the plane. It might not need to go all the way in the front, but you should check now before realizing that, because of the lengths of you wiring, you can't push your battery all the way to the front with the motor mounted at the rear. Solutions would be to add extensions to the wiring or be prepared to add nose weight to the plane to get her to balance.
Looking forward to seeing the next iteration.
