Size gliders for soaring ?
Bruces
so the tiny trainer with a little larger wing right balance and weight will thermal real good. here was my first attempt then i moved to a new fuse with the same wing. View attachment 148516
https://forum.flitetest.com/index.php?threads/foam-thermic-50x.19074/#post-208479
the thermic 50x i did is a bit more difficult of a build but i regularly out soar balsa models these are both cheap ways to see if you like to soar my 50x uses about $15 of gear and $3 of building material
Although it is not easy to build, it is very exciting to see it fly, and it can be painted in different colors as you like. Do you plan to give your gilder a colorful look
dutchmonkey
Not really i put some red tape on the wing to make it more visable at altitude and fly it as often as i can.
