Theuglycamel
Ok, I know this is frowned upon and just so everyone knows, I take VERY good care of my batteries. However, for about year now, I've been using 2600mah 18650 canister and 1200 "flat" LiOn batteries out of laptops. The weight ratios are comparable and over the years I've collected DOZENS of these guys. I never run them without a timer and never more than 20% of cap.
And just so everyone knows, I'm not condoning the use of canister lithium batteries. They are DANGEROUS if you're not careful. Think about all the times you've puffed a lipo. If that were a Lion, you would have had fireworks inside your plane. The reason Lions are able to be used in laptops is because of the extremely dynamic charging systems they use. With that being said, be sure to balance charge, always charge outside or in a protected area, and never over amp lions. Also, be wary of gutted batteries. With their use/misuse unknown, the chances get much higher for an accident.
Disclaimers out of the way, I've built several 2s, 3s, and 4s setups with both of these versions of Lion. I'm also going to be using a pair of them in my fs-i6x. I figure I've made about $300 worth of bat packs over the last year and I still have dozens of laptop packs to gut. I just tore another 9 out of an old thinkpad last week and I'm planning on setting up a 5200 3s pack for the Golden Goose MkII. But that's another thread for another time. I will say that I get much better performance out of the Lion packs than I do with Lipo. This isn't a very fair comparison though since I only buy Lipos on the cheap. Lions do seem to take a bit longer to charge, they don't seem to get nearly as hot, and they HATE the cold. I don't know if this is just because of the casing or just their age. Also, I have yet to have a Lion go bad on me. All of these were old (10+ years) and after a couple of break-ins they all have worked flawlessly over and over and over again.
I've only had one lipo blow up on me (ejected straight through a 9x5 dynam prop) but I've had SEVERAL nicads blow their tops. If you've ever experienced a NiCad blow, imagine that with the incendiary properties of lipo added. So be safe, be creative, and remember almost EVERYTHING has a battery in it. Getting em out in once piece is the trick...
