Balsa
bracesport
this looks a bit faster! :D
bracesport
In continuing the balsa theme, I am liking the idea of designing a slope glider in wood/balsa in the style of the 'Rock4K' 80" which I like the look of, especially the wingtips - I am unsure whether to go V tail (which you know I am a fan of) or a traditional rudder/elevator (the Osprey 100" from the '80s has a nice one) - I am thinking to target 80" (2.0m) and go with dihedral/ailerons/flaps/elevator rather than a polyhedral/rudder/elevator. :)
bracesport
A bit more progress on the wing to add the tapered section before detailing the flaps and ailerons - I am using the 'Osprey' plan as a reference, but my wing panels have different proportions for the tapered position - the 'Osprey' is a polyhedral wing and this will be a dihedral wing (at this point) - an interesting process so far. :)
bracesport
I have mostly finished the wing and tail - as this is for laser cutting the joints are also detailed to make for a better kitset - the next stage is to rough out the fuse - although I am using the Osprey100 as a scale guide I am designing my own version of the ROCK-it-4K and as most of you guys know I do love the 'V' tails! :)
Wildthing
View attachment 182923 View attachment 182924 View attachment 182925 View attachment 182933 View attachment 182934
What are your plans for covering?
bracesport
Here is the rough assembly.
The fuse is just roughed out and will get a makeover, but it is indicative of the direction - the wing needs to be sheeted at the front of the tapered sections and there is no rib bracing yet - it is set up for ailerons and flaps - this one could be converted to a power glider.
I call it 'the Verve'! :)
Blackadder
Well, on the back of some great builds in Balsa (especially @rockyboy 's builds) I have been inspired to build one myself - I have picked the SLOPEMASTER which I think it looks awesome - It is an old school design using old school techniques!
The first step will be to CAD it up in 3D from the Plan template!
View attachment 147159 View attachment 147160 View attachment 147161
Hi Bracesport.. was there any CAD files released for the Slope Master for laser cutting, or any STLs for 3D Printing..
Llaserfly
