slot prop vs pusher
81zapper
I'm designing some more jets and would like to know which is better.
having a slot prop type set up or have the motor right at the back.
Is one system better than the other?
Craftydan
Hostage Taker of Quads
"Better" is relative.
The slot is easier to get the CG right (motor is farther forward) and will have better control at lower airspeeds (prop wash is over the tail control surfaces).
The pusher is structurally stronger (no hole in the middle of the airframe), is a bit more flexible to the airframe you're modeling (tubular fuselages aren't as well suited for a slot, but still can be done), and is generally much more scale in looks.
jamboree1
Typically for me prop in slot is an easier plane to balance. Rear mounts need a long nose to help achieve proper CoG
