cdfigueredo
I like your idea, i ws thinking to mix solution 2 and 3 by using a removable cap that will be used to refill the powder compartment. the can print caps with different diametre holes and test them.Unless the hole is ridiculously large the turbulence will be almost nil. Air tends to pile up in front of an obstacle like that and sort-of forms its own fairing. It seems easy enough to start with a small-ish hole, fly a test flight, and then slowly drill bigger holes until it starts being a problem.
Also i can start testing solution 2 ad then replace it with a cap with a hole on it.
