To add to what I already said, I thought about doing this too and I was going to make a physical switch powered by a servo to turn the motor on and off. My concern was landing. You'd want the motor at least off for landings.
To add to what Jtnb said, a larger glider is the way to go. You may want a 2200mah 3S (or 2S) battery in it so you can get a really long flight time. Servos eat power, not just the motor. Plus if you do put FPV equip on it, that'll eat the battery quicker. You may not have to go ridiculous, probably at least a 60" wingspan.
http://www.flyrc.com/wing-load-calculator/ Use this calculator to figure out the wing cube loading. 3 to 4 is what you'll want.
I'm not sure you'd be able to use your blue wonder or not. If you do, do
NOT use that ESC to power the Rx. You'll likely to get power drops, brown outs, and black outs when powering it with solar panels. Get a 12v solar panel, do not plug the red wire of the ESC into the Rx, use a different ESC or BEC to power the Rx, hook it all up and see what happens. But I'd think that cloud cover may drop the volts and amps to the point that you burn out the ESC or motor. A brushed motor may be the way to go just for the simplicity of it. Hook the motor directly to the solar panels with either a relay or a physical switch powered by a servo to turn the motor on and off.
