Hi all, I'm working on an FPV tank that uses 360 servos to turn the tracks, and I want to increase torque and speed. I was looking at the servo's spec sheet and the speed and torque of the servo increases with voltage. So instead of using power supplied from the receiver could I solder the positive and negative wires to a 5v source (yes the servos are rated to handle that) and then solder the signal wire to the receiver?
It seems like this would work, but I thought I'd ask first just to make sure.
