Cpt Adventure
Firstly, yes a newbie doing my first build.
Hexcopter (X)
KK2.1.5 FC
SimonK 30A ESC
920 KV motors
Spektrum DX6i
F550 frame
So everything is hooked up and just getting ready to mount my props (which are now balanced).
But when I go from throttle 0 to throttle X. Six of the motors (m3-m6) all start together. M2 was sputtering for awhile so after reading this forum , I swapped the ESCs between M3 and M2. That seemed to work. That was yesterday.
So today, I go back to continue my adventure, ensuring the motors are all turning the right way, and I discover M1 and M2 are stuttering. But if I crank the throttle to about 20%, M1 will start, and then at about 25% M2 will start and all the motors are running.
So, this is normal, qwirky, or magic?
I know bad connections are discussed and I check my bullet connectors between ESC and motor repeatedly. Unplug, wipe clean, insert, turn, tight fit. Try again.
Thanks in advance.
Hexcopter (X)
KK2.1.5 FC
SimonK 30A ESC
920 KV motors
Spektrum DX6i
F550 frame
Thanks in advance.
