@SP0NZ, Hi Dan, I've noticed an error in your FT simple cub plan. On the wing spar, the right side is 1/16 inch shorter than the left side, as a result, the servo hole is 1/16 inch closer to the center wire hole, so it doesn't line up to the wing servo hole correctly. See my attached screenshot, I did a quick measure in acrobat reader, on the left side, the distance between the servo hole and the center hole is 4.08, while the on the right side, it's only 4.01 (1/16 inch is 0.0625). Both wings the servo hole and the center hole are 4.08 inches apart.
Dear SP0NZ
About the plan of the Mini Sparrow:
I noticed an error: two of the lines in the body-fuselage are not correct: the lines between the botton and sides. They are black/full and should be red/striped.
If you would really cut them through as is intended with black full lines, you end op with a fuselage-part in three pieces instead of one.
Hi Sponz,
Thanks for all the great work you do. It makes build these plans much better.
What CAD software do you use to create these plans? I want to make some modifications to one of the FT designs.
Thanks
where are the A-4 and F-5 plans?
Do you have the tiled plans for the Air Hogs Intruder that you built for Flite Fest?
thanks for the reply ben, as much as I admire Andres x29 I do prefer the look of the f5. i just want a something that is not OTT to build (although i do like a bit of a challenge) and something that is fast, presumably this jet ticks both of these boxes ? i think ill build it from your plans on the build thread.
Sponz... so i just have to say. I just built my first FT design that you haven't gotten around to revamping yet and i do have to say... HUGE difference between the stock plans and yours. Thank you SOOOOOOOO much for the time that you have put into this! Seriously...
