SP0NZ - Plans Index
I just wanted to say a huge thank you to Sponz for doing all of these designs and drawings/plans for the community. I am brand new to this hobby and am currently building a couple of planes from these plans. Thank you so much and I shall call my first plane "The Sponz Special" in honour of your hard work and kindness. Many thanks my friend.
Joe
SP0NZ
FT CAD Gremlin
Joe
@JJAB99 You are most welcome. You guys are the reason that I do what I do.
And thank you so much for the kind words.
@SP0NZ first thank you so much for everything you do! A question on some of the new master series plans. I see some of the parts situated on the plans that go against the grain with the standard DTFB. For example the p-47 fuse part the overlaps the wings. When transferring would you recommend rotating the parts? I don’t know if the FT foam has the grain issue but the DTFB definitely does. Thx!
SP0NZ
FT CAD Gremlin
The parts are laid out on the plans without any regard for grain direction. They are aligned for optimal spacing and minimal seams across the pieces for the most part. I assume most people do not print a full-size plan and lay that on the foam to cut out the parts. You should arrange the part plans on the foam board for the desired grain direction and to optimize yield.
When the kits are laser cut do they cut them to mold with the grain?
