Spektrum IX12 issues.
epiper93
I was wondering if anyone else had issues with their IX12's binding and staying bound to an AR636A receiver. Which is a pretty common receiver in Horizon BNF's. I have some that bind to the radio work fine for a flight or so then they lose connection, I have no telemetry data but it says I have a connection but no servo response. Sometimes If I lie them on a flat surface it'll bind fine and the problem will subside. But that doesn't work all the time. Any suggestions are appreciated. Never had this issue with my DX8G2.
JimCR120
Got Lobstah?
Site Moderator
I have the DX7 not the IX12. My only binding issues are when I try to bind with the tx too close to the receiver. I typically hold the transmitter at arms length away from the aircraft and find it binds every time that way. As for losing the bind I can't say but would make sure the tx is on and active well before powering up the rx. Normally the closeness of the tx after initial bind hasn't been a problem but maybe you might want to try that.
How many rx's are losing bind to the tx?
