'SPIT' roasted FB
chris398mx
I finally was able to get some building done tonight. Started on the hybrid wing.......smooth top with under-camber and ironed edges.
Remove paper in this area for smooth airfoil.
Airfoil profile
My first attempt at ironing the edges.
I used smeared hot glue to reinforce the under camber.
Smooth top airfoil
Here is the new wing compared to the standard FT wing. Smooth as a baby's bottom. I am getting excited.
Hopefully more to come in the next day or 2.
BATTLEAXE
Airfoil profile
Smooth top airfoil
That's looking sharp bro. On point. Did you use a modeling iron or a cloths iron for the edges?
buzzbomb
I know nothing!
CarolineTyler
So this is the rear top which is normally posterboard card and I struggle to get it smooth. This is the 2mm thick vector board and I've cut it to flush up against the top of the foamboard. Being much thinner I need to support it so there will be little runners for the vector board to stick to. No idea if this will work but I really don't like the Flitetest method of sticky tape and overlapping it.
IMG_20190819_203245990.jpg IMG_20190819_203300411.jpg IMG_20190819_203323886.jpg IMG_20190819_203432953.jpg
CarolineTyler
@CarolineTyler - that is essentially what I did (but with FB) - I made the whole piece as a complete tapered section which worked out ok, but I think your method with the 2mm board might be neater! :D
I'm going to try gently heat forming it to reduce the stress from it trying to straighten out. I'm really using this plane to test out materials and the techniques needed to using it.
BATTLEAXE
Great job guys, really taking it to the next level on these planes. cheers to @CarolineTyler for using new different materials to achieve the goal. As for the edge at tangent trick, doesn't John Overstreet still use HG to bond all his master series butted connections and masking tape to hold in place till it sets... or am I thinking of a different strategy altogether :unsure:
buzzbomb
I know nothing!
What is this mess??!!
Wellllll..... That's a plane ready to fly! :D I stripped the receiver from my Baby Blender, soldered up the new bec to the faulty esc, and attached the new Turnigy motor to the power pod. Then wired everything up. I've glued in the control horns and run the linkages...
That mess is a bird that is hopefully going to maiden on Wednesday! :p
bracesport
@buzzbomb - well done - I kind of knew you would sneak up an be first at the line - I am expecting some radical flying! :D I still have my tail to build, some RP's to do tomorrow for the exhaust stack, and the paint is drying on the spindle! :LOL:
what prop are you running?
BATTLEAXE
Will you be the first of the group to fly the Spit?
