I always use the prop adapter with the threaded shaft. It works well and honestly, I like the prop being the weak part. I’ve only crashed my ft-3D once and I hit the wingtip and it swing over and hit the prop. You can barely tell you hit the wing tip and since the prop took the majority of the hit, it saved the rest of the plane. @PoorManRC bent his motor shaft but if I remember correctly, his prop was ok😱 I’d rather buy a new prop than a new motor...I actually saw the blade of the APC prop go flying off towards the horizon, when it crashed. I ripped it right off at the root. I haven't used a prop saver before, most of my motors have threaded shafts.
That is scary! I don’t think I want to trust any of my planes, especially like you said on a higher power model.I only use a prop saver on lower power models....the though os a spinning wheel of death only held on my a thickish rubberband scares me!!!
