I love it! It’s what I thought to do on my Howard DGA-6 build and you proved my concept to work so thank you .So I am ready to start construction on my master series inspired SPIT based on the model below with rounded fuse and under-camber wing design. One more note ... this will be a 48" wingspan plane.
The parts laid out ready for cutting.
I am going to go for a combination style wing between the regular angular wing on the current FT style spit and a smooth top wing like the master series. I don't care for the non rounded leading edge on the master style design so i am going to try the hybrid shown below. I quickly took a scrap piece of foam to fold and try the concept. I removed a section of paper from the inside of the wing to get the smooth top surface and left the paper on the lower flat side. This will give the smooth top and the nice leading edge.
top view: the end of the wing tip is missing because of the small piece of scrap I had. just wanted proof of concept.
Under camber will still be present.
Should be a nice blend of the 2 styles.
What do you guys and gals think? Any suggestions?
Well , it is not in they air yet, so we will see. but your welcome if it helps.I love it! It’s what I thought to do on my Howard DGA-6 build and you proved my concept to work so thank you .
I will be really interested to see the details on the build just like how you started out. The master series really takes it to the next level as far as FB goes. Do you have a PDF on the plans you could link in?
As far as the poster board tip I suggested, it's pretty simple. I don't know how skilled of a pilot you are, I know I am not skilled so this is what worked for me and you can take it to whatever variation you like. Maybe you are one of those "only the wheels touch the ground, nary a scuff on the airframe, planes last a lifetime" kinda pilot, then totally disregard this tip. I just used HD poster board, (cuz I do crash a lot, and have bent many wing tips just getting the plane into the car), and adhered it to the underside of the wing with spray adhesive applied to both the wing and the poster board. the poster board was cut over sized before application and trimmed to fit once in place and dried, as shown:
Have you already done the original Spit and now stepping up the game or are warbirds new territory?
Real nice, great job.Well that's all the foam and poster board work. I think it looks pretty good so far. I need to find a nice paint scheme and get a big spinner on the front.
View attachment 139743 View attachment 139744 View attachment 139745
Sweet, are you ironing the edges or some other technique?Well that's all the foam and poster board work. I think it looks pretty good so far. I need to find a nice paint scheme and get a big spinner on the front.
What an excellent mash-up of the original design and your mods taken from the idea of the Master Series! The flaring on the wings is exceptional, the cockpit is inspired and your wing-scoops are a nice, added touch! Beautifully done! I'm really looking forward to the maiden video on this one!Well that's all the foam and poster board work. I think it looks pretty good so far. I need to find a nice paint scheme and get a big spinner on the front.
You might check out some of the free (online) balsa plans for 3 view/plans with sections on them.As far as the design,
- I just used the existing plans from FT and scaled them up to adjust for the size wings I wanted.
- Found a side profile picture of an actual spitfire and then inserted it into the drawing.
- Scaled the picture until it matched the length of the plans
- Then i started drawing front view profiles of what i thought the plane should look like from the front matching the height of the fuse in that area.
- Then i created the model in the 3D CAD software using the profiles for the formers.
Beautiful, Love it!Well that's all the foam and poster board work. I think it looks pretty good so far. I need to find a nice paint scheme and get a big spinner on the front.
Great smooth wing design, and the flairings, is that the same technique on the flairings that @nerdnic uses for the P-39?Well that's all the foam and poster board work. I think it looks pretty good so far. I need to find a nice paint scheme and get a big spinner on the front.
Thanks for the tip.... I will check it out.You might check out some of the free (online) balsa plans for 3 view/plans with sections on them.
There's a whole list of resources on the FTFC20 thread.
Awesome work........ All you guys are making me look like an amateur.Thanks for all the positive reviews everyone.
I can't take any credit on the design, this is simply a @nerdnic spitfire 800 scaled up to a 1080 mm wingspan with a few mods to make the scaling work.
I suggest checking out his plans. @Rasterize @BATTLEAXE
Although there is no build video for the spit, my process mirrored his nnp39 v2 video.
@kilroy07 - I didn't use the iron much at all for this one, actually, which is good since i usually get too overzealous and end up making wrinkles in the paper. The horizontal and vertical stabs were done by cutting each part twice. I removed the paper on one side and did large bevels on the TE and shallow bevel on the LE glue and then cut he hinge. Nick did this in the nnp39 v2 build video and i think the extra thickness makes it a bit more scale. I only worry this is making it a tad more tail heavy. all other parts have a nice paper fold-over on them.
View attachment 139770 View attachment 139771
That made me smile. I'm familiar with that feeling. The company I keep on this forum generally does that to me. It's a great way to improve my skills. That's one of the reasons I love the group builds so much.Awesome work........ All you guys are making me look like an amateur.
