Spitfire76's Build Log of 3DAeroventure's B17
Spitfire76
With a wingspan of 83inches (2108mm) and a length of almost 60"(1520mm) this will be a very ambitious 3dprinted plane build.
I had considered building this B17 for sometime but was put off by the price of the retractable main landing gear (~$650) then a friend and fellow club member asked if I could print the airframe for him. Once printed I will provide him the parts to assemble and fly.
Design by https://www.3daeroventures.com/
Designer's build log on RC Groups
Spitfire76
Fuse1-2 parts printed with 3dlabprint's PolyLight 1.0 LW-PLA (gray). I was able to use the supplied g-codes on my Ender 3 v2 but did add a G29 after the G28 in order to perform the bed leveling. Parts are large so they took a very long time to print. There is also some stringing but is easily removed with a X-Acto knife and is mainly on the inside of the fuselage. The internal supports are printed with Bambu Matte PLA on my Bambu Lab's P1P.
Spitfire76
The founder of 3DAventures was a special guest on episode 77 of the AviationRCnoob podcast were he spoke about his designs.
Spitfire76
I am getting good prints from using the g-code files but ran into a problem with Fuse5. This is the largest of the fuselage files and it was trying to print beyond the right edge of the bed. This is the G-Code loaded into Cura.
The g-codes were generated for a Prusa i3 Mk3 which has a bed X-axis dimension of 250mm whereas I am printing on an Ender3 which is 235mm. The g-codes assume that the X-axis center is 125 mm (250/2) from the home position (0,0 front, left) but really should only be 117.5 (135/2) which if my math is correct it needs to be shifted 7.5 to the left.
It turns out that the fuse5 was not centered on the I3 Mk3 bed either so I needed more that 7.5mm offset so tried it with 30mm.
I replaced the G28 in the original file with the following.
G28 X0 Y0 (home just X and Y to front left
G92 X30 (make it think its already at 30mm to the right)
G28 Z0 (home Z)
I also add a G29 after this as my Ender had the bed leveling feature.
Its printing now although the first layer was not great which I believe might have been to do with having the offset with the auto level.
Its only 13% and has been printing for 3hrs so this will be a 23 hour print.
Eventually I would like to print the LW-PLA parts on my Bambu Lab P1P but at the moment its just easier to use the g-codes on the Ender.
CrshNBrn
I printed some of the parts to this plane then filled in the rest with foamboard. It actually flew pretty well until I lost the hatch, battery, and the rest of the plane in a spectacular collision with the ground. Good luck with your build, Spitfire76- its a gorgeous airplane!
Spitfire76
It will take you less time to solve it if you open the STL Fuse5 part in Cura and slice your own Gcode.
I know but it became a bit of a self imposed challenge to change the G-Code :)
Anyway thanks for pointing out the original build log on RC Groups.
I have joined that thread and I will try to catch-up with those posts.
I also added that link to the first post of this thread.
Spitfire76
The LW-PLA parts are lighter than the estimated weights maybe because I am using 3DLabPrint's PolyLight 1.0 instead of ColorFabb's LW-PLA. On the other hand the PLA parts are a bit heavier so hoping it will balance out.
LW-PLA Profile AEst Weight (g)Act Weight (g)
Fuse14035
Fuse23025
Fuse38874
Fuse49278
Fuse57060
Fuse66455
Fuse76253
Fuse82321
Fuse92825
PLA Profile BEst Weight (g)Act Weight (g)
Fuse Tray 1/23839
Fuse Tray 34856
Fuse Tray 43638
Fuse Tray 52523
Fuse Tray 64847
Fuse Tray 72019
Fuse Tray 898
Spitfire76
Printing has continued since my last post .
I got bit distracted by the release of Eclipson's B17 yesterday. It has a smaller wingspan of 1700mm compared to 2100mm for this current build.
It just looks a bit odd, maybe not as much to scale as the 3DAeroventure version.
Spitfire76
Its just over a month since I started printing the parts for this plane and I estimate that I am about 90% done. My poor old Ender3 has been printing all the LW-PLA and I have had it running most days and nights. My friend who will build this plane wants to install clear plastic in the window sections so he is looking into that process.
Spitfire76
Its been awhile since I updated this build log but the printing phase is almost done. Just need to print the flaps. The total print time for the LW-PLA is 433.5 hours!.
narizz28
I'm building a different B17 model from Eclipson at the moment. I tried printing a fuse section of the 3DAeroventure B17 first, but with active foaming LW-PLA the stringing was unbearable.
Spitfire76
I did get quite a bit of stringing printing the B17 parts but it was always on the inside and removed most with a knife.
Spitfire76
As it's nearing the end of 2025 I am checking each of my FT build logs as I know some, maybe most have not been updated for sometime.
So the story so far for this B17...
Firstly it not me that is continuing this build but a friend and fellow AMA club member who has taken on the challenge. I, with some help from another friend, 3d printed all the airframe parts and I just started the fuselage assembly as shown in the earlier posts.
One of the concerned I had from the very beginning of this project was with the availability and price of the retracts as the company, Robart Manufacturing was no longer making them. It turned out they had sold the IP to HighVizRC and although it took them a month or so to tool up my friend was able to eventually purchase them. Now the cost...the total, just for the components for the main retractable landing gear pair was almost $750!
This plane is large and heavy so will need some well made landing gear and I am sure the price is justified but it's just the major cost of the build.
One option is to have fixed landing gear (at least initially) which is what I am planning to do for my own build in 2026. The RC Groups thread also have found some less expensive options for retracts that I will consider.
