dmaximob
I am in the middle of designing my first scratchbuild plane. I am basically starting with the FT Mustang plans and modifying them a bunch to create a Mooney M20. I've got the fuselage and tail worked out, the wing is going to take me some time to get the leading edge shape right, but the part I'm having a tough time with is the split elevator of the Mooney. I can't quite figure out how I am going to control both sides of the elevator equally.
I've seen a couple methods that seem to look good, but I feel like they take away from the the look of the plane. For example, a BBQ skewer or some rod spanning the entire elevator controlled with a single control rod. I've seen photos of someone who made a 'Y' out of the control rod but I can't quite figure out how to create a solid reliable connection at the 'Y'. I have some reservations about using one servo for each side, but am wiling to do that if necessary.
I was also wondering if there is a such thing as a double linkage stopper. One that I could put on a single servo's arm that has a linkage stopper on both sides of the arm. I've done some looking but haven't found anything like it.
Are there any simple solutions I'm overlooking?
Oh, and maybe the more difficult hurdle is that I want to keep the control surface hinge angles, so I'm not sure if that will limit what I can do.
