Maiden
Took full up trim and almost full stick deflection to fly, need to figure out if it is a throws issue or a CG to forward issue. Both 'normal', where the elevons moved as one, and split, were there was an 80/20 split on movement [inner more elevator, outer more aileron], flew well. given the extreme level of elevator input, I don't feel the yaw test was valid as the inner servos were close or completely saturated, leaving no additional movement for the yaw input to effect it.
Second maiden flights of my split elevon wing attempt. I swapped out the ~101g battery with one that was about 40g bringing the CG back 3cm or so from the recommended situation. The wing was still very stable in pitch and didn't need nearly as much up-elevator to fly straight. Unfortunately it was rather draggy in the air and if I cut the throttle completely it would descend very fast. Definately has a fairly poor glide slope.
Unfortunately the yaw control didn't do anything useful. However the wing itself flew fairly well. The flags at the edge of the park were flying full and coming in over the southern trees (I noted at one point in the video which ones) and I am quite sure there is a band of significant turbulence in the area.
