Starting out on FPV
I don't know anything about those. These are custom built for the type of flying I do.
Chances are, those have limited use for FPV
Bricks
That is basically what I had before worked Ok I thought until I did get a soldering station. For me the biggest downfall was not knowing the exact temp it was running at when I would adjust it. Just My Two Cents. Soldering station does not have to be high priced to get a good job done I think mine was around $80.
Mine has a temperature adjustment with a digital display for showing the temp.
I wanted to know if there is much difference in video quality between these cameras? Thanks!
The first one is PAL only but has a better field of view for flying outdoors and better low light sensitivity. The second one is NTSC and PAL but has a wide field of view that would be OK for a tiny whoop flying indoors.
Really going to depend on what you intend to fly it on.
I want it for a fixed wing aircraft. I didn't know if the cheapest one would be okay for me right now? I do want to do some "flying in proximity"
The problem with a wider angle camera flying outside is it becomes difficult to judge speed, altitude, and distance.
When starting out, either will do. You will learn over time which suits your style.
Do you think the third one will work fine then? The cheapest one.
Oh, I didn't see the first one. Of the three, I would not get the first. It's quite a bit more than the other two but almost as wide of an angle as the third.
So it would be between the second and third....
Okay thanks! Think I will go for the first being that I am on a budget and I can always upgrade later!
