its a tricycle gear and I want the front to be steerable because there is no rudder on it and I want to steer it on ground even though I might have differential I want that part scale. its ok if there is no easy way to make retracts
You need something like this. A steerable nose gear from Dubro
Retracts look great but they are not nearly as durable as fixed gear. Unless you are flying from very smooth runway and are very good at landing, I would not recommend retracts.
Common setups are using the rudder servo to control both rudder and front wheel. So just set up one servo and run one linkage to your front nose wheel. I have no idea how one would do it with retracts if you went that route.
