Double Shot Banks
Hello,
I dont have pictures at the moment but i need help with an ARF kit i have no instructions to on the nose gear.
The front of the plane only has one opening on the bottom right before the engine, the engine mount has a small hole that fits the nose gear perfectly, it goes right through and lines up so i can hold the nose gear in place. It has a plastic piece that has 2 arms off of it with holes, i assume these are where the pushrod attaches and goes to the servo. only problem is this piece does not fit on the nosewheel when it is in the plane, its too long on both ends and the engine mount gets in the way. And there is only one whole in the firewall and thats for the gas tube and throttle servo pushrod. The steerable nosewheel piece is too wide a pushrod cant go through this hole. Also there is not mounting piece to hold the nosewheel in place.
If you know what im talking about please help. I will get pics up ASAP
Isaac
Isaac
