Still up a tree
Does need to be schedule 80 otherwise after two lengths it makes a big arc and touches the ground. metal conduit perhaps? Spray foam filled?
So I was flying my Profile Edge yesterday and I tried a flat spin, but it got pushed by the wind over some trees, so I pulled up and...snap the wings folded. Now it goes into a real flat spin into a tree (about 56ft up). So I got out my bow and arrow (so cheap it can't go 20ft high), but that did not work. tried throwing a hook with a weight but again that did not go high enough. So I took out my Profile Xtrem 3D and put a bomb trop on it, attached a weight at the end of the rope and then placed it on the bomb drop. So I flew the plane over the tree then droped the weight, land the plane, try to pull on the rope to shake the tree, but even though I made the tree shake a good bit it stil would not come out (I think it might have a servo wire tangled around a branch or something like that). So I kept on tying to fly over the tree with my plane, but it was getting dark so I lost orientation of the plane and WAM into the tree. So now I have TWO planes stuck in the same tree (the second one is a bit lower). Now what do I do? Rain is coming in two days so I need to get them out before then. BTW the tree would be very hard and dangerous to climb.
Any ideas welcome. @LitterBug @Houndpup Rc @Mr Man @Mr NCT
OUCH!! I suggest PVC or conduit👍
The tree they are stuck in is basically unclimbable. I tried using my drone to drop a branch attached to a rope but it won't grip the branch properly, but I did get close so I will keep on trying.
Careful not to get the drone caught! That is a LOT harder to get out as it a lot smaller and not as light and has a bunch of props to hang up on stuff...
