Hi,
I have a fairly new build and In the first few minutes of flying the video feed is really clear even at full throttle but once the lipo gets to around 18v (I'm running 5s) video noise starts to appear. This video noise only happens though at high throttle inputs and it's pretty bad. The strange thing is that even when I give a small blip of high throttle and return to hover the noise appears and stays for around 3s even though the quad is just hovering.
To tried to fix it by soldering 4 470uf capacitors directly on the escs however this seems to have made it a little worse because now there is a minimal amount of noise even at the start of the flight and once the lipo voltage gets to around 18v the noise is worse than before.
Setup:
Betaflight F4
Wraith 32 v2 escs
Hypetrain 2306 2150kv motors
Tbs Unify pro V3
Runcam micro Eagle jb
Both the the vtx and the fpv camera are powered off 5v and I soldered both the ground wires to the agnd pad, I also have isolated the sma connector from the carbon fibre.
Any advice?
Thank you for your help
Setup:
Betaflight F4
Wraith 32 v2 escs
Tbs Unify pro V3
Any advice?
