telnar1236
The assignment was submitted this morning! I am so glad to be finished. It was a very interesting project, but a lot of work. A formula was derived, but I'll post that with an explanation later. By using the formula to graph bending strength against different dimensions, the following two discoveries were made.
1. Strength does not increase proportionally with spar cap thickness. A graph of this is shown below for a spar 12mm wide and kept at a constant total height of 18mm, simulating the thickness of a wing. This is because a bending moment is a force x distance, and the added balsa wood on the inside is at a smaller distance than the rest of the balsa spar caps.
2. Bending strength increases greater than proportional to the total spar height. This means when you double the total spar height, the bending increases by a factor slightly greater than 2. This is caused by a similar reason to the spar cap thickness disproportionality.
If you haven't already, you should look into how the area moment of inertia affects bending strength. It might help you combine those two observations into a single statement.
I look forward to seeing your results!
