Su-47 build/question thread.
Foam Addict
Squirrel member
Hey guys,
I have a project which will need all the help I can get.
I am constructing a DtFB Su-47, and need some advice on stabilizing my wing structure, as well as control surface sizing and bracing.
The first model will be a flat 2d model for proof of concept. 30" wingspan.
Depending on the success of the first, the second should be around a 40" wingspan, full fuse.
Thank you to everyone in advance!:D
Craftydan
Hostage Taker of Quads
FA,
Nice idea for a plane -- like the layout so far.
I take it you're planning to add a profile fuselage and fins?
xuzme720
Dedicated foam bender
FA, forward swept wings are very cool but particular attention needs to be paid to bracing them, both in torsional rigidity and spanwise. Flutter was a real problem with some of the first ones until the materials caught up strength-wise. How fast are you wanting to fly this? Some strategic use of carbon fiber will save the day, I think.
Craftydan
. . . and here comes Xuzme with the cold wet blanket of physics ;)
Good point -- some CF stripping mounted upright along the leading edge (or just behind) would stiffen the wing nicely.
xuzme720
Sorry, Dan. Someone has to be the voice of sanity and reason. Let me know when we find that guy... :D
Foam Addict
Squirrel member
Thanks guys, I read that it's a good Idea to build in washout into the wing tips,and that they have a stress aoa effect that feeds on itself untill the wings snap. I have CF I can use, triangles any one? Edit: Slow! I'm thinking light and manueverable.
rcspaceflight
creator of virtual planes
When I built a profile X-Wing (yes, from Star Wars) I had a KF step on the top wings and I didn't have any issues with the wings folding. However, my second one I didn't have the KF step all the way to the center and the wings folded a bit at the fuselage because it wasn't braced there at all. The bottom wings on my X-Wing folded right away because I had no KF step or bracing on those. I just used two bamboo skewers to brace it without issues. I flew my X-Wing slow also.
From personal experience I can say that simply adding a KF step to the wings should be enough bracing. Plus you'll have more of an airfoil. So it's a win win.
The CG for my X-Wing ended up being right at the leading edge of the wings. Of course an X-Wing doesn't have forward swept wings, so your CG might be a little forward from the wings. I had a real issue finding the CG. With the wings in back like that, CG is extremely important and very touchy. But starting at the leading edge or a little before should be a good starting point. If it's too far back, your plane will do a back flip. If it's too far forward, you will have no control over it.
Here is a link to my X-Wing, just because I think it might be helpful to you: http://www.flitetest.com/articles/star-wars-x-wing
EDIT: I should say that CG is extremely touchy because my X-Wing was a pusher, with the motor in the back. I'm not sure if the pickiness of the CG was because of the wings being in the back, the motor being in the back, or both.
Foam Addict
Squirrel member
Thanks, a forward CG is definitely the way to go. Except with a wing, then it better be spot on or it always finds the fence post where I launch!:black_eyed: I'm a pretty intermediate scratch builder with about 30-40 aircraft that I have scratch built. However only 4 of those were jets, and of those I had a 75% failure rate. Only one worked.
This is jet is a big leap, but a feasible one, I'll post progress after school.
Foam Addict
Squirrel member
Yeah! I got a 30 min break!
I already rediscovered the freakish engineering nightmare called canards. Mk II will have a 3mm carbon rod and old motor bearings as well as a digital servo for their actuation.
Foam Addict
Squirrel member
Another short break and a graphing calculator later:
Here's where I really need input. Where should the motor go? I have a 200 watt 2200 kv motor that should work okay.
Should I have a flat plate airfoil? A flat bottomed airfoil? Kf step?
What size of ailerons?
Bracing ideas?
I had thought about rimming the wing with CF strips, but I don't know how that will handle twisting motions.
Craftydan
Prop-in-slot is usually at the CG . . . but you don't know where that is yet . . .
finish the build out with servos/receiver/esc, then glide test it. using the battery to set CG. once you're happy, cut the slot to mount the motor right on the happy-place for CG.
xuzme720
Bracing ideas?
I think RCSpaceflight had a good plan with the KF step for your wing. I would try to get at least some carbon fiber in there as well due to the possibility of torsional twist, I'm thinking straight across as far forward as you can and then a piece on each wing from near the vertical stabs to the wing tips to form a sort of triangulation.
Ailerons can probably be 3/4-1" running tip to half span or 3/4 span. I would keep the throws low if you go the full inch and 3/4 span. It should be very responsive at those dimensions.
As far as motor location, were you thinking of pusher or prop in slot or something else? I know RCpowers and others have had a lot of success with prop in slot builds...plus it might be easier to balance that way.
I'm also hoping you'll have a lower keel of some sort to brace where the cutout for the canard servo is. That looks like it can be a very weak point.
Foam Addict
Squirrel member
Okay! Dan, maybe I could test it as an rc chuck glider before I put a motor on it.
I have a huuuge hill near my house that would be useful for that purpose.
Xuzme, yeah, sorry I haven't finished the belly structure nor the Fuse reinforcement yet.
That bracing is a great Idea. Thanks a lot!
A KF 2 or 3 looks good. Does anyone have experience with a KF 3?
My only KF plane was a trainer with a KF 2 but that was 2 years ago. Have to go dig it out...
I'm not sure how to brace a prop in slot on this plane. I'll go watch the Ft-22 episode.
Foam Addict
Squirrel member
More progress! I'm thinking of putting the motor about 3 in. Behind the Canard servo.
Learning from other builds, I installed a 1/2 in balsa nose block under the nose to provide strength and nose weight.
I decided to go with a simple flat bottom airfoil, I know it, I love it, and the last thing I need is another variable.:black_eyed:
Edit: sorry, really bad pic, I can't seem to get rid of it.
rcspaceflight
I'm guessing that the CG is going to end up about an inch in front of your airfoil. I agree with CraftyDan that if you do a prop and slot, the closer you have it to CG the better. But if I where you, I'd cut the hole for the prop in the thickest part of the plane so you'll need less bracing. That looks to be close to where the CG will end up being. I don't know if you'll want the motor in front of or behind the prop, that probably depends on how it balances.
By the way, great looking plane.
Foam Addict
Squirrel member
Nice guess! Yes that's where the glide tests have the CG right now.
Thank you, this is one of my best builds so far. How much bracing do you think I will need for the slot when I cut it out? I am thinking about a 7 inch butterfly slot to eliminate noise.
Craftydan
oh, a few peices of 1/2" square steel tube should do nice . . . Oh! you want it to fly too?!?
How wide is the fuse there? planning on pusher or tractor mounting the motor in the slot? I'f you've got some CF arrow shafts, or similar, might run it along the outer bracing 3-4 in forard and aft of the slot (that would be my TLAR, but might be able to get away with less).
Foam Addict
Squirrel member
Fuse width is 6" total usable width is 9"' pusher configuration, 6 inch prop, yes I was thinking of running that last forward straight spar through the motor mount
Sorry, I'm still a complete noob at park jets.:eek:
By the way, initially I'm going for canard aileron throttle control, followed by elevator.
The canard can have any where between 10 and 165 degrees of throw, I'm thinking of starting around 20 degrees with lots of expo.
Craftydan
Fuse? 6" total usable width, 9"' pusher, yes I was thinking of running that last forward straight spar through the motor mount
In all fairness, I've never finished building a Prop-in-slot before either -- I just know how a few have been designed. A 6" fuse is gonna get you, maybe you can scale out a bit (stretch it to 7-8")? There's no rule saying the motor *has* to be on CG, it's just easier to design that way (especially for ARFs where pople like to pick diffrent motors). If you move it farther back you'll have more structure to play with, but you'll have to move other things forward to keep balance.
BTW, With a 2200kv motor, 9" prop seems *awfully* long (running 2S or 3S? 4S?!?). I'd expect something like a 5-6" electric prop, spinning at those RPMs -- won't be hard for a tiny prop at that speed to draw close to 200W.
What's your AUW at? (with your motor, of course)
