I'll second Baron's Vapor vote *as long as* you have at least a clear 20x20' room. I've got a finished, enclosed 2-car garage (20x20x8'), and I can *barely* fly a figure 8 w/o going into high alpha (plane is hanging from it's propeller, not really lifting w/ it's wings). If you have the indoor space, you have the advantage of flying whenever you have time. When it's calm outside, it's a joy to let it go. Very stable, very slow, very easy to control.
Will help learn attitude & orentation (which way is it pointing, do I move the stick right or left to turn the way I want to go), throttle/elevator managment (throttle for altitude, elevator for speed), Crash damage avoidance (chop the throttle when you're in trouble) and yes, minor repair. If you go this route, get a 1mm prop saver (hard to find, but worth it) and check out the
vapor mod thread over on RC-groups for tips to repair and reenforce the weak points.
