Super Cheap Cessna
#22
Time to build a cowl
I was at walmart and I saw a fiber glass repair kit for fourteen bucks, so I bought it. I am going give fiber glassing a try and hopefully make a nice cowl for the Cessna, hopefully.
I read some were about using foam for the mold. After you fiber glass the foam mold, you dissolve the foam with acetone and your left with a fiberglass cowl. It sounds simple enough. I will make sure to take pics.:cool:
#23
I just finished the cowl it still needs paint. For my first try it looks okay. Here are the building pics, enjoy.
marking the foam mold
cutting it with the hot wire
fiber glassing the mold
more fiber glassing
foam mold dissolved
testing the cowl
just need paint:D
#24
That's awesome. I've got 3 weed eater motors down the shed that I've been wondering what to do with. I'd always thought they would be too heavy. Time to have a look at some of those plans.
Tritium
Amateur Extra Class K5TWM
#25
How do you keep the sand bound for sand casting. That has always been mysterious to me.
A bit late in my reply but:
Old way was motor oil and sand and as you can imaging it was a smoking mess when the hot metal hit it. I prefer investment casting with plaster but the plug has to be burned out of the mold either before (more difficult to burn out plug material) or during casting (lost foam).
Thurmond
#26
I am wondering why you inverted the engine? The weedeaters I fly are vertical. Seems super cool though! What kind of pistons did you use to increase compression? I wanna add some power to my 25cc :p:p:p:p:p:p:p:p I wanna make it hover!! hahaha
also BEAUTIFUL BUILD!
bicyclemonkey
Flying Derp
That's the correct engine position for that model. Most gas engine'd planes position the cylinder pointing down. If the cylinder was pointing up he'd have to cut a nasty hole in the top of his cowl. Also this points the exhaust downward, too.
Jaxx
#29
First of all, this is really cool! I noticed you were using a stock 9X Tx/Rx setup. Not to "rain on the parade" but I didn't think it was recommended to use this Tx/Rx setup on gassers like this. Am I wrong? I use the same Tx/Rx (6 channel version) setup on my planes, but I believe the lack of failsafe in its stock configuration was one of the reasons for this recommendation.
