Masterguns
Hello, people. I'm a man with many inquiries on my new journey with FT planes...
I'm almost complete building my Scout XL. I killed the rudder servo with too much torque I believe. I'm using four Surpass Hobby 17g. I've have good success with them & their motors before. Would it make a difference if I use one of my surplus FMS 17gr servos in the stash? Would it affect the Aura5 Lite controller with two different servos running on the same electronics? I had used the standard fare FT landing gear wire that I routed though a tail wheel bracket that I 3D printed that's very similar to the one's FT sells for their XLs. Lined the aft wire portion to be square with the coffee straw in the rudder itself & used a Dubro 1.5" light (the foam ones) wheel.
Perhaps I stripped the servo because the glue reinforcement applied after the bevel cut still made it too stiff & the servo just torqued itself to death? I think I will cut the rudder off & reattach with hinge tape or some of my plastic pin hinges. I think either of those two would help swing the control surface easier in my particular case. I've got Corona 22gr coming from HK which are known for better torque value & are still very light on the wallet. I've fashioned a new wire set up with some stronger pushrod wire that's more flexible & I'm using a salvaged 1/4" foam wheel. What do you say? Thanks.
Best regards,
Masterguns
Best regards,
Masterguns
