TurtlesThatFly
Hello fellow Flitetesters!
This is a foamboard B-52 that I am working on. I had a thread in the Electric Fixed-Wing section of the Electric Flight forum, but I realized this is a better place to post this. So here it is! Intended to be Depron, this B-52 is aimed to become a simple design that can be put together and flown in less than a day. Currently, I cannot afford Depron to make this, so it is made of foamboard (If you live outside the states, make this plane by covering both sides of 27x29 3/4" 4mm or 5mm depron on a paper with the same dimensions, using 3M Super-77 sprayed on both sides or on one side of each paper).
I will post daily (and on good days, hourly) on the progress of this backseat bomber. If anybody has suggestions, please reply in the comments! I will probably incorporate your suggestions in the design of this airplane. Stay tuned!
Old thread (mods feel free to delete it): http://forum.flitetest.com/showthread.php?35959-Super-simple-foamboard-toilet-paper-roll-b-52
Here's the beginning of the B-52!
Cardboard toilet paper tubes (use 8x)
Tracing, measuring, and cutting out the foam
Fuselage cut out (mind the hundreds of drawings)
Glued the fuselage together. Incorporates A-Fold technique
