augernaught
Augernaught
First post, please be nice!
This E-motor stuff has my short-and-curlies tied in knots!
Best I can figure is my SuperTiger .10 is actually bigger? than the 480 motors (or BEEF?) I read about
and used in the Swap-Spitfire?? (don't look like it in the pictures, mine "looks" smaller but
it's mount is too big to fit the Swap motor plate even on a 45* "X" angle.
It even has a 4mm shaft vs the 3mm, but the vids keep saying use what you got, and go from there.
I don't have anything else, and just some 9 X 4.5 and 9 X 7 SF props in my box.
What should I start with, for what I got on the W-Spit??
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXXGY4&P=ML
SPECS: Mounting Space: 1.5" (38.7mm)
Diameter: 1.4" (35mm)
Length: 1.18" (30mm)
RPM/V (kV Rating): 1250
Weight: 2.4oz (69g)
Input Voltage: 7.4-11.1V
Max. Constant Current: 29A
Max Surge Current: 33A
Max Constant Watts: 320W
Max Surge Watts: 370W
No Load Current: 1.2A
Suggested Prop Sizes: 10x7E - 11x7E
Connectors: 3.5mm Male Bullet
Motor Shaft Size: 4mm
I have to mod (embiggen, a-la the Simpsons cartoon) the motor mount/power pod by about a 1/4 inch downwards,
and that does not bother me as much as not knowing if this motor is enough to power the Spit
Dave W designed, using a 2100 Venom lipo and 40 Amp esc. amd TowerPro 9G servos.
Just hope my batts fit under the extended pod!!!
I built the Spit, (first Swap too!! free plans build) but I don't enjoy crashing my planes as much as the FT crew seems to do. I spent a lot of time building and painting her, and I don't have companies sending me free stuff, so............
Any input on my concerns??? Is this ST .10 motor enough??
ANY advice for what I have to work with will be appreciated greatly!!!
TIA
Oh, and I do have a tiny bit of fly-time under my belt, but only with Tower Hobbies WarBird/ARF's
on a Tactic 650. I have all three, and this is the Hellcat.
Bad thing to start flying, but this vid is my first solo... after only one buddy-box a-la my AMA club:
Wing and Rotor of Western New York. (Yes FliteTest. Niagara Falls, but in NY!)
http://www.youtube.com/watch?v=19GMCqhT8s0&feature=c4-overview&list=UU6EcVpFBG7L1I4las12E-PA
Let me know what you think about my motor....
Weight: 2.4oz (69g)
TIA
