michaelj_00
Thanks guys and gals for having a great forum. I've been lurking here for some time, but now I need your help. I searched but couldn't find my answer.
My kids and I built a tiny trainer using some of the recommended electronics. I'll include the links to the components so there is no confusion on what I am using.
When I program the esc to lipo mode the following electronics combination cuts the motor off after about 3 seconds.
For testing I've used two different motors, two receivers, and three batteries. They all make this esc do the same thing. (I only have one esc so I can't compare the esc.) Transmitter is a Dx6i if it matters.
If I add servos to the combination they still function after the motor cuts off.
Suppo 10A esc
http://www.altitudehobbies.com/brushless-esc-bec/suppo-brushless-escs/suppo-10a-brushless-esc
Turnigy nano-tech 2c
http://www.hobbyking.com/hobbyking/store/__11896__Turnigy_nano_tech_460mah_2S_25_40C_Lipo_Pack.html
Emax 1806
http://www.banggood.com/EMAX-MT1804-2480KV-Brushless-Motor-For-Multirotor-p-933933.html
OrangeRX 615x receiver
http://www.hobbyking.com/hobbyking/...MX_Compatible_6Ch_2_4GHz_Receiver_w_CPPM.html
What is strange is if I hook up a 3c 800mah the motor works just fine.
http://www.hobbyking.com/hobbyking/..._Lipo_Pack_E_flight_Compatible_EFLB0995_.html
Is this esc just not compatible with these batteries and if so why not? They are the recommended batteries by flite test.
P.S. if I run the esc in NiMh mode these batteries work just fine.
Thanks,
Michael
Suppo 10A esc
Emax 1806
Thanks,
Michael
