Swappable Foam Cub by Shaun Martin 2014'ish?
Masterguns
I'm building this plane. I'm using DTF, however, which is half the weight of what Shaun used. I'm trying to determine what would be a good motor, esc, battery & prop sizes. He said in his article that it should be at least 350w. I'm thinking a 2400'ish motor, 30-40 esc, 3S 2200mAh & 10" slow fly prop. What say you? Thanks.
Happy Saturday to you all!
Masterguns
...What say you? ...
You'll need to weigh the plane ready to fly, if necessary estimate the weight of the motor and battery.
Watts per pound is a useful guideline to match your indented flying style.
• 50 to 70 watts per pound is the minimum level of power, good for park flyers and lightly loaded slow flyers.
•70 to 90 watts per pound is perfect for trainers and slow-flying aircraft.
•90 to 110 watts per pound is good for fast-flying scale models and some sport aerobatic aircraft.
•110 to 130 watts per pound is what you want for advanced aerobatics and high-speed aircraft.
•130 to 150 watts per pound is needed for lightly loaded 3D models and ducted fans.
•150 to 210+ watts per pound gives unlimited performance for any 3D model.
Masterguns
Thank you for your detailed explanation(s)...same goes for the other thread you replied to me with help. I think I'll only need 70-90w/lb range. I'm not a speedster, 3D or sport type flyer. More like a Cub guy, so to speak, so that range should serve me well. Although, not exclusively FT, this one will presumably be the lightest of the type I've built, but we'll see when I get the motor, esc & battery chosen & installed. Only have the cheap HK 9g blues installed for control surfaces thus far. I gotta have a wounded finger repaired Monday morning, so I'm going to be just downloading plans & watching the build vids for at least two weeks. Thanks again for sharing your knowledge! Have an awesome weekend!
Best,
Masterguns
