Taking FPV Desicions
OK, I recently read this awesome article about an FPV setup on the FliteTest site, and also chatting with nonamerc over here.
So anyway, I was filling up too many comments on the article, so I decided to continue the discussion here.
So what I'm looking for is the cheapest solution available, while still maintaining a reasonable quality.
Defined requirements are:
- Not 900 MHz - cellphone network interference
- Not 2.4 GHz - radio uplink interference
- More or equal to 200mW Tx power
- Range 1Km with homemade cloverleaf and skewplanar antennas
- No goggles
- HobbyKing stuff preferred
- Minimal complexity
- Aiming at portability
I was considering 1.2/1.3 gear because of the reduced range of 5.8, but I'm eventually tempted to use 5.8 as it seems to have less harmonic interference from 2.4 (so it requires less or no filters).
This is the current watchlist. It might take a year until I get started with it, but I can still learn a lot.
Tx/Rx
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=15295&aff=524347
Camera
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=13434&aff=524347
I like this camera mount (eve if I would only use pan with the rudder channel, maybe a switch to control tilt)
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=12875&aff=524347
Any cheap 7" screen off of eBay.
Any metallic case to make it as awesome as this:
This is the conversation so far:
I've only had the opportunity to test this setup on my quadcopter, as I'm currently building my plane right now. That being said, I've flown FPV on my quad within LOS but beyond my capability to distinguish it with my naked eye. How far that was? Hard to tell, but I would guess somewhere around 400-500 meters. I'm sure it could do a lot farther considering other's have achieved much greater distances on the same hardware.
Sounds like enough range for me... I love your clean setup, I'm totally making something similar when I get my gear! Is there a reason you prefer 5.8 over other frequencies? I've heard that 5.8 gives you less range at the same power output...
I'm glad you like it. I chose 5.8GHz for two reasons. First, I remember seeing one of IBCrazy's videos a while ago where he explained that 5.8GHz has the ability to transmit higher quality video as opposed to the lower frequencies. Second, the antenna selection in 5.8GHz is a lot smaller and more compact than any of the other frequencies. In my case, the cloverleaf and skew planar fit very easily into a small case because they were compact. If I had gone with 1.3GHz or some other frequency, transportation and portability would have become a problem. Now, it is true that due to the high frequency of 5.8GHz you won't be able to pass the signal through many hard objects and a clear LOS is required most of the time. However, with some good circular polarized antennas you can get a descent signal through many hard objects. As a test, I was able to get signal reception through 6 walls in my house, two of which were exterior walls. This was pretty decent for my use, so I think I'll stick with it.
Also, just a side note...5.8GHz with a skew planar and a cloverleaf can give up to 5km in range. Other frequencies like 900MHz can give much greater range, but I don't ever think I'll be flying more than 5km![]()
With the 200mW? I think that's with higher power transmitters...
Yep, that range can be achieved with this setup. Here's a video where someone reached 7km using a 200mw 5.8GHz setup. They had a cloverleaf on the transmitter and a 6-turn helical on the receiver. http://youtu.be/thwJGbdCa0M
Well, that's understandable with a patch antenna... I'd personally prefer omni reception. How do you think this would work out? http://www.hobbyking.com/hobbyking/store/__15295__5_8g_200mw_FPV_Wireless_AV_Tx_Rx_Set.html http://www.hobbyking.com/hobbyking/store/__13434__1_3_inch_SONY_CCD_Video_Camera_NTSC_.html http://www.hobbyking.com/hobbyking/store/__21283__2_1mm_F_2_0_Turnigy_Micro_FPV_Camera_Lense.html http://www.ebay.com/itm/7-TFT-LCD-C...ltDomain_0&hash=item256ecc72d8#ht_2903wt_1396
those all look like good items for an FPV setup. The only thing I might suggest is keeping your eyes open for a better deal on a 7" screen. There are lots of other vendors on eBay that can ship a 7" screen to you for around $25.
