jamieFL
Taranis' Variable Proportional Elevator Trim (OpenTX)
For those flying with the FrSky Taranis or the new Horus, I want to share a quick little function that will automatically adjust your elevator trim as the speed of your model changes. It should only take about 5 minutes to add to any of your existing models, and is adjustable while flying using your throttle and elevator trim switches.
If you are unable to get your plane properly mechanically trimmed, you probably have to adjust your trim constantly as your mode's speed changes. This little function can correct for that.
Please give it a try and if you like it, post a comment on the article. Also, if someone could let me know if my directions are detailed enough or if I need to clarify anything.
http://www.vectoredair.com/frsky-taranis-automatic-elevator-trim-opentx/
