I have a Taranis X9D Plus Radio - Mode 2, But when I go into CleanFlight to check out the Receiver tab settings it shows the left stick is set to Roll. Does anyone know how to make the changes so the Left stick is Throttle and the Right stick is Roll?
the good thing about the taranis is you can map each stick to whatever control you want.
are you conneting your d4r2 receiver with ppm? I am guessing that you're using a naze32 board. ppm means you can connect your receiver to your board with just a single cable.
No biggie but this post is not really relevant to this thread. In future you might be better starting your own or picking threads more carefully. There is a Taranis discussion thread somewhere.
However, as far as I can tell the Taranis X9D Plus will bind with the V8FR-II.
"Compatibility FrSky X series,D series and V8-ll series receivers"
I don't have one so I cannot test it.
I haven't found anything on the discontinued V8FR. V8-ll rx's can use the D protocol and seem to be supported via the D8 setting on the Taranis, so possibly you would need a older V compatible 'JR' module to use one of the older V series.
