TBS Discovery Naza M v2 Gains, HELP Please!
TBS Discovery
920 kv motors
Naza M v2 w/GPS
3S 6A/6000mah battery
I seemed to have gotten everything dialed in with quite a few test flites. The issues I am trying to figure out is getting the hovering a bit more stable and less touchy when moving the throttle(should I move the vertical gain up or down and why?), next is when its windy which has been everytime I flew when the wind comes I get a little wobble going (should I move the pitch/roll up or down, or just one up or down?) when just test flying I get no wobble and it only happens when the wind kicks up, lastly is the YAW gain setting, when trying to spin arround to get a 360 view of my surroundings while hovering it tends to drift even when in GPS Atti instead of staying in its GPS locked spot and spinning around(should I move the YAW up or down?). I found a page of gain settings for the discovery, but none are close to my current settings which are fairly stable, some are 30-50% higher then what I have now. If anyone has a setup close to mine and has stable settings even when getting 100-300 feet up please share. I do a lot of video and would like to get it my gains as stable as possible. I would use a nob, but I use one X for tilting the camera up, down, and middle, and the other to switch between modes. I guess I could disconnect the camera tilting and use the nob and see what happens.
