tgy i10
I’m back...
It turns out that this transmitter has a default setting that doesn’t allow to kill the motor above 50% of its travel. The only reason I can think of for doing this is so if your flying a quad or helo, the last thing you would want would be to hit that kill switch and have your bird fall out of the air. So it requires you to get into the system and change the assigned switch for the type of air vehicle your about to fly. This has to be done for each aircraft type obviously because if it were a general kill for all aircraft in your transmitter you would have your helo and quads falling out of the sky. So in order to get around the default condition (C1), you need to go into the Conditions page, and choose a condition (2,3,4,5,) and assign a switch you want to kill the motor. On the conditions page, you’ll be able to choose conditions 2-5. When you do that you’ll be given another page that allows you to rename condition, mine is C3 throttle and at the bottom of this page is a switch icon which allows you to select the switch you’ll using to kill the motor. Note: the up or down indicators refer to the position on the switch on the transmitter not the function of the action. Back out of this page and go to the Throttle curve icon. At the bottom of the page, press the gear icon which will take you to the parameter options. Choose the first one since it has the least options and it will be a lot less hassle. This should kick you back to the previous page where you’ll see diagonal red line running from lower left to upper right. Now through the switch you’ve assigned for you throttle kill (cut). You should then see the condition number show up, Cond 3: throttle. Now press (L) if its not already 0.0’d out and use the roller at the bottom to run it down to 0.0 and do that for (2), and (3). Now back out of this page and select the Throttle down icon and at the bottom of this page there’s an switch icon, press that and select the same switch for the throttle kill you selected in Conditions options. Before leaving the throttle down page, with the roller at the bottom of the page , run the Idle up % down to 0. If you don’t do this, when you hit the kill switch, the motor will not be killed, but will be at the % of idle you left in that option.
I don’t believe the sequence of these changes makes a difference, but that the changes are where they need to be to get what you want.
All this is a bit of a hassle but only until you learn the procedure.
Hope this helps somebody with the same problem.
Thanks for your help PATK
