TH Freestyle vs THII Race vs THII Freestyle
Mr_Stripes
So I'm looking for a good micro and these just keep coming up. My question: Is it worth $20 more for 200mw? I am just flying freestyle around my house and I want something durable and agile. What do you guys think?
Thanks,
Mr_Stripes
PsyBorg
Wake up! Time to fly!
Thanks,
Mr_Stripes
If you have your HAM licence then 200mw (actually 50mw to 100mw) would be better for penetration thru walls and such and it shouldnt be so powerful to interfere with wifi in the house. the dipole antennas wont be the best for penetration or reflections so 25mw could be iffy depending on your RF situation where you live.
I use this on my Gremlin set to 50 mw and its perfect for indoors as well as out where I fly my bigger quads as well.
https://www.amazon.com/dp/B075FQ96QY/?tag=lstir-20
here it is on the Gremlin before I made the decision this was the VTX camera combo I wanted and put it inside for protection.
PsyBorg
How does that gremlin fly with the inverted rear props?
They arent inverted. They still push the same way and are mounted the same way. I just underslung the motors and reversed their direction to make them pusher.
OG Gremlins are a blast to rip around. This was all flown on 3s and is just as controlable as 2s just a higher pitched sound and MUCH bigger top end out in the open. With proper rates and good throttle management you can fly a 5 inch on 5s Like my big builds indoors if you have confidence in your skills and set up. You can get them tight enough that full stick pitch deflection results in a 10mm - 20mm per second velocity.
Check out the crazy winds this was flown in. Watch the trees in the opening scene.
