Can I sub-trim a plane in my DX8G2 without a negative effect on the Aura? Such as "Launch Assist". I thought Josh at FT mentioned doing it before...on a video. Just can't find it now....Thanks!!
Short answer is no. You need to go through the Quick Trim option, which moves any of the trim from your TX to the Aura.
"Because a variety of control algorithms are used now and in the future, it is important that the Flight Controller know true transmitter 'Stick Center'. A traditional transmitter combines the pilot's stick position with trim and subtrim in each channel. Since the Aura has no way to differentiate transmitter trim or transmitter sub-trim from transmitter stick input, transmitter trim and sub-trim should be avoided. Any needed trim/sub-trim offsets should be made in the Aura Servo Ports (or with Quick Trim, or mechanically). Aura contains special routines such as Quick Trim to allow you to easily set your trim/sub-trim in the Aura at the field without a PC application."
