The big bang of Mustangs
ColoFlyer
Finally finished my full size P-51 Mustang. Came out better than expected. I made some changes and some upgrades you will see in the following post. I haven't been out to maiden it as yet, but when I do, I will post a video.
ColoFlyer
I didn't really like the way the FT landing gear is put on so I fired up the 3D printer and printed out an alternative. The design of the main gear might also work on some of the Master Series planes. There is a part that hot glues inside the wing and up against the spar and protrudes through the bottom of the wing. The wire gear fits into the protrusion with a bend in the wire keep it straight, then a plate screws on with 3mm screws to secure the gear in place.
ColoFlyer
I don't like having the servos outside on the fuselage, so I printed a servo tray and put them inside. I also used metal gear servos for better performance.
I also printed a piece that replaces the 2 pins that hold the power pod. I have had to many FT pins rip out and this setup makes the power pod attachment much stronger, plus if the pins break I can just unscrew the pins and replace the piece with the pins.
I also added a steerable tail gear that will help when it is on the ground. I just used a coat hanger bent to fit the gear.
chris398mx
Looks Great, would you mind sharing the stls?
ColoFlyer
Absolutely, I would also be able to modify them for a different size gear wire if anyone needs the change. Also I can put up the fusion files if anyone want to modify them.
The Main Gear parts are set up for a 2.5mm gear wire, if you need it to be larger like 3mm, it will need to be modified. It also uses 3mm screws for the plate attachment, no nuts are necessary. Part one Hot Glues, or Gorilla Glues inside the wing during build, then the screw on plate will sandwich the gear wire and a chunk of foam board to give support. I printed Part 1 at 40% infill to give it a balance of weight and strength, but you can use what would work for you. If you look at the pictures of my installation, you will see a small piece of foam board glued on top of Part 1 inside the wing, This piece gets a spot of glue when I folded the wing and presses against the inside of the the top wing board.
The Tail Gear is setup for a 2mm gear wire and can be modified for for a different size if needed. The hole in part 1 needs to be snug but loose enough to turn easy. (I used a coat hangar that I bent for the tail wheel.)
The Power Pod Pins just slides on where the skewers would be. I had to cut a 2mm recess where the pins press into the front, so that the back tabs of the power pod would snap into the slots in the fuselage. ( Hope that makes sense.) Then it is held on by 2ea 3mm screws, ( no nuts are necessary)
The Servo Tray just hot glues onto a couple of pieces of foam board attached to the inside of the fuselage.
Let me know if you have any questions or need a modification in the files.
  • Mustang Main Gear part 2.stl
  • Mustang PowerPod Pins.stl
  • Mustang Main Gear part 1.stl
  • Mustang Tail Gear 1.stl
  • Mustang Tail Gear 2.stl
  • Mustang Servo Tray.stl
Stress Test
What kind of silver paint is everybody using? The stuff I have smears and then is dull where it smeared. I tried clear coating it (on scrap) AND that didn't work.
I just picked it up. After it has dried for a couple of months its not so bad.
Its not finished obviously, I kind of hate to destroy it until I learn to fly better, and if I finish it, I'll crash it.
:D
Edit for spelling.
ColoFlyer
I use Rust-Oleum 2X UltraCover. Seems to work great for me. I can usually coat a foam board plane in 2 light coats of this, no sanding needed.. I pretty much only use the brown water resistant foam board if that makes a difference.
The Hangar
Fly harder!
So in this post I'm going to list everyone who's building a mustang and which one once they’ve printed the plans and started cutting the parts out out foam:
@K3V0 - mini Mustang
@The Hangar - mini Mustang and standard Mustang
@mayan - mini Mustang
@buzzbomb - Standard Mustang
@Grifflyer - modded mini Mustang
@dutchmonkey - Mini P-82 (oh yeah!)
@mach1 rc - standard Mustang
@Ketchup - “4s mini mustang” yep - another one!
@MiniacRC - mini P-51C
@Sero - mini mustang
@Wildthing - standard FT Mustang
@BS projects inc. - MONSTER mustang
@ScratchBuildMast - Standard ft mustang with a Corsair wing "mustair"
@Hoomi - standard ft Mustang
@CrazyFastFlying - mini mustang
@Marty72 - standard ft Mustang
@rickp mini mustang!
@ColoFlyer standard-sized mustang!
@Stress Test mighty mini mustang
@mackaiver mini mustang and p-82 twin mustang
I counted it up and we have had 20 mustang builders - way to go guys! Keep them coming! :D
TenienteDan
One more here, a mini!
A little story about how amazed I am with this plane.
I started on this hobby this summer after watching a random video of a guy building a Cessna like foam plane.
I build it too and learned (aka crashed a thousand times) a lot on building and piloting them.
Then retired that plane and finally built a Simple Scout. Amazing plane, I love it's versatility. I got very confortable with it, acrobatics, touch and goes and not a single hard accident (but the last day when I stuck it on a tree lol).
And then I built this little beast. OMG this is almost like starting over again, feeling super nervous and having to focus 100% to control this little plane. 10 minutes on the Scout were feeling very short and kind of boring already, but 5 minutes on this MMM is exhausting.
I had a very good maiden experience (although I end up landing below my friend's scout... happily no damage) but today I crashed very hard, breaking the wing... (I could fix it easily).
And given that the servos are very exposed, I think one is already malfunctioning.
Can't wait to build another one, and eventually, I will build the bigger too.
slowjo
how about the P51c Otter, after Japan bombed Pearl Harbor , the Japanese actually occupied an island of Alaska, so this is my rendition of what our military would have come up with if they were able to push further into US territory. We would have needed some War Bird Sea Planes!
The Hangar
Fly harder!
That’s great to hear you’re enjoying it! Flying really is a rush - you have to stay so focused since letting your eyes leave the plane (especially a zippy little one like the MMM) will likely result in a crash.
