Good luck on the maiden. A few tips on it that's rarely mentioned. 1 check your C.R.A.P., after you do that, check it again. 2 make sure the prop is facing the right way, the numbers always face forward on a tractor setup, or even pusher setup unless said prop is specific for a pusher. 3 and this is very important. Launch with the sun at your back and never fly behind you, and if possible don't fly directly at yourself until you learn the controls and plane orientation. 4 get someone to hand launch the plane for you, if not possible launch with no more than half throttle at a slight upward angle and a mid effort toss, if it won't fly at half throttle it probably won't fly at all. 5, relax, it's just foam.
