Had some Labor Day fun. I have some old 0930 tri-blade props I don't see ever using, so purely for fun and curiosity, I decided to try something Cranial
suggested.
To cut them down and put them on the mini. . .
They work. . . after a fashion. I can't seem to get them perfectly balanced. I have them darn close, but the vibration is still moderate. With such an extra wide chord, I made them 4.5". I did a couple ultra short, 'Spruce Goose' "proof of concept" flights of about one minute each. It was a cool experiment, but they'll come off after I get some video.
Also tried the GoPro tabs I put on the front. I added it for the unlikely option of using the GoPro for FPV. Works OK, but I'm uncomfortable putting $400 out in the open like that.
Now, on to the more pleasant discoveries. I've been noticing when my mini flies faster and faster forward, it's taking less elevator to keep it level at speed. It's flying a bit like hydrofoiling, where pushing the throttle higher makes it 'float' upwards with no elevator input. It's been hard to evaluate this phenomenon in detail because it's been horribly hot and I have yet to go to a field where I can push the throttle close to wide open for more than a second, but I believe it's getting deflection lift. The vertical flat booms tilt forward and appear to actually be gaining some lift as opposed to the booms of box-type mini where the booms are laid flat. As those fly faster and faster forward, the booms will actually push the quad down as it deflects the air stream upwards.
Another tidbit I ran across. I knew having thin booms in planform were energy saving and efficient, but had no idea how much.
Below is an old MIT education video from the National Committee for Fluid Mechanics comparing planform area in an airstream. What literally
blew me away is how critical it is to have an airfoil IF you want ultimate efficiency, and not just a small planform in the airstream. And to stress that in spades, is the comparison of an airfoil of macro size, compared to a thin wire . . .
Check it out at time 04:35.
I must admit, I was a little doubtful of my results in the videos
I shot a few months ago comparing boom planforms, but now believe they are much more accurate than I suspected.
