The finer points of combat wing design
jetpackninja
More combat please...
Hahahaha- I just built another one.
I'll try to get some pics up tonight and hopefully get a maiden done tomorrow (if the weather holds)
I personally don't recommend them as first planes, but they are so durable that I know several people who learned how to fly with them. Even if you don't fly combat, it's worth having one or two of these things in your hangar.
jetpackninja
OK- no full blown tutorial but here are some pics of my new EPP Assassin Combat plane from CrashTestHobby.
All extreme taped up and ready to laminate
a4747735-71-DSC04962.jpg a4747736-232-DSC04963.jpg a4747737-137-DSC04964.jpg
All lammed up
More tomorrow, will hopefully maiden if the weather cooperates.
jetpackninja
Yes- it's CA safe. I'm a hot glue man myself ;)
What is the KV on the CF2822? I'm sure it's big enough but you may need a bigger prop if it's lower KV than the CF2812.
My setup is bigger than the recommended setup and way heavier.
I use:
HobbyPartz 3010 Rocket Series motor 1700KV with a 7x6 APC clone prop
2200mah battery to balance the big motor
MG90S servos
HobbyKing 25-30 card programmable ESC
Orange 6 receiver
I have another one setup stock with the FC2812 motor and a 1300mah bat- Flies well too. (will still go straight up- just not unlimited)
Build as close as you can to the instructions on the CrashTestHobby site and you will be a happy customer :)
There are a couple of places I deviate from Lee's build instructions but they are minor...
jetpackninja
Got the maiden on vid.
Got some video that I took after a couple 'o packs getting more comfortable with the plane.
Will post it once I figger out how to edit out some of the boring bits.
earthsciteach
THe CF2822 is a 1300 kv motor. It produces 19 oz of thrust on a 7x6E. Not too far off from the 2812 @ 21 oz of thrust. Looking forward to watching your video, but my wife is calling me to come watch Swamp People with her! Gotta love that!
jetpackninja
Just to add another log onto the fire and fan the flames...
Been working with Zach on his first combat wing.
Hope to have this one ready to maiden by next weekend.
colorex
Rotor Riot!
So I happened to notice the ailerons for your assassin - are they EPP? cause I have found some insulation type material, but it's not at all rigid, it's sold in rolls, not in sheets. It looks like solidified soap foam. But it would have to be quite reinforced to work for a plane.
jetpackninja
Yes- They are EPP. The way the ailerons come in the box you could tie them in a knot.
They become rigid after covering with two layers of the laminating film or by wrapping with Extreme tape and then covering with a layer of laminate.
colorex
Rotor Riot!
And what lamination is that?
jetpackninja
It comes with the kit, but it's a film that is used in automatic laminating machines.
It is shiny on one side and a little tacky on the other side.
You apply it like you would monocote or similar iron on covering but it becomes crystal clear when it is activated by the heat of the iron.
colorex
Rotor Riot!
Oh, then I don't have that option.
I'll probably end up scratchbuilding with EPS anyway.
teflyer
Full Circle
#37
In my opinion, EPS is not a good option for scratchbuilding. I built my first scratchbuild , the MidiDart, from EPS. It flew, but broke way too easily, even with a gentle landing by friend who already knew how to fly RC. I would go with Artboard or Elmer's foamboard, or something similar.
colorex
Rotor Riot!
I don't have that! I only have EPS available! I have no other option!
