Basic stixs
Chad what if you added batteries to both sides of the box... This may help with the roll issue.
Please excuse the simplicity of theis drawing, I'm away at the moment, and only have a laptop with MSpaint and a track pad...
Lying awake in bed last night, I had a think about this project, mainly to do with keeping the VTOL aspect. I thought about Tom O'Connells idea for moving a weight side to side, making it bank. But I thought about using this to move the CG forwad and back to change from VTOL to forward flight mode. Please excuse the simplicity of theis drawing, I'm away at the moment, and only have a laptop with MSpaint and a track pad...
So basically, on the centre line right behind the motor, you have a servo with parrallel arms going to a battery tray. In forward flight mode, the battery is moved to the edge of the box, creating a forward and low CG.
Then the battery is moved back and to the centre line for VTOL. The CG is then more in line with the centre line and moved back, making it more stable for prop hang.
You would need to have a gyro on the aileron channel of your elevons though, otherwise you'd have all sorts of torque roll going on!
The transition from VTOL to Forward flight might need to take 3~5 seconds (just a guess) but it would be interesting to see what would happen if you put it on the landing gear channel and just switched it! But if you had it on like a pitch trim channel, then you could tweak the CG dynamically during flight, as well as make the trasition more smooth.
Some tweaking of the servo endstops would need to be done to keep it within limits.
Couple this with an added rudder, and I think you'll be well on your way.
NAM
P.S. Yes I think its disturbing too that I was thinking about Chad in the middle of the night.....
No prob, man! MS Paint is the best graphics software ever!
(Image was a bit big and off topic)
NAM
The flying box thing has been done quite successfully -- see:
The Voltair Tech Cube was sold as a kit about 10 years ago. It's made of nylon with a carbon fiber frame, and uses only vectored thrust (no control surfaces).
The shape of the box is slightly asymmetrical for aerodynamic reasons (of which I am unclear).
The Cube was reviewed on RCGroups in 2003...http://www.rcgroups.com/forums/showthread.php?t=210475
I have one of these kits NIB that I've been meaning to build!
