Wildthing
Got that NASA "research aircraft" colors I see
It's first flight will be research so I though it would be fitting.
And you're testing this plane right?It's first flight will be research so I though it would be fitting.
So the throttle is set to a 2 pos. switch?!Beta version and my extra mods so WOT
I'd add a v-stabWorked on a new plane tonight... found some old wings from a walmart glider and decided to have a spin at it. I know this has been done before but here’s my take. any thoughts or things i should watch out for?
Ive been thinking of that, not sure exactly, I havent tested it at all. might try a single vert stab on the center fuse. thanks!I'd add a v-stab
You are going to want winglets on the tips for yaw stability. A Vstab in the center wont do anything for you. You need drag on the tips behind the CG to keep it from shifting on the yaw axisIve been thinking of that, not sure exactly, I havent tested it at all. might try a single vert stab on the center fuse. thanks!
Excellent point, didnt think of that. Will Do!You are going to want winglets on the tips for yaw stability. A Vstab in the center wont do anything for you. You need drag on the tips behind the CG to keep it from shifting on the yaw axis
You are brilliant man I wish i thought of that!... Oh wait, I did lolOr some wing tips.
Now that was fast! How fast do you think it was @SquirrelTail ?Off topic... did a flight with the FT Bloody Baron on 4s today... lots of fun!
Clocked it on my old setup with a 9x6 and a Turnigy D2836/8 1100kv doing 81mph, This setup is considerably more powerful (SunnkySky 2216 1250kv, 10x7 prop) I will have to try and get a reading sometime!Now that was fast! How fast do you think it was @SquirrelTail ?
