The Great 2020 Quarantine Build-Off?
Crawford Bros. Aeroplanes
Hmm, too bad. You could use some epoxy to glue two wires together...
I could use landing gear wire, but the thin stuff is on back order on the ft store and I don't feel like spending $10 on wire anyway. The issue is that I had to go further out from the wing root than you did to get past the popsicle stick I had glued to the top for the rubber bands. In retrospect I should've just cut the popsicle stick shorter.
BATTLEAXE
Got the little Jug all painted up...
Was thinking of putting decals on it, like the Star and Bars over the tail stripes or even sharks teeth up front, but that would just add more weight
I will say it did turn out pretty sweet, and straight from all visual angles, now just to fly it, that will be the real story
The Hangar
Fly harder!
Got the little Jug all painted up... View attachment 169607
I dig it! What motor are you going to fly it off of?
The Hangar
Fly harder!
I have been looking at some higher Kv 2205-2207, probably 2300kv at the lowest. Which brings to mind actually I have a crapload of 0645's to use up, I might be good to go on 3s
Sweet - I just picked up two of the ft radial 2206 2500kv motors that were on sale.
Vimana89
I've got a frankenplane thing that weighs just a hair over 250g fully loaded. I made it from an old(custom) stick plane's stick and tail feathers. It flew pretty good when I maidened it today, but have since added features(paint on the tail feathers and a circular prop guard that also supports the nose a bit). it looks pretty odd, but is easy and smooth to fly. I'll take some pics soon and post it.
bracesport
@BATTLEAXE - Nice to see you are continuing to set new standards with each build! :D
